re force parts
rlovioi
Hello, In my last post I was'nt clear, sorry about that. What I was wondering, will a stator and trigger assy. from a 90 or a 150hp force fit on a 120hp of approx the same year. I looked for part #s in the mega mall but none for 90, 120,150HP. Does anybody have a link or first habd knowlege. The cdi and coils are the same but thats all I seen. Thank you Ray
eurolarva
Re: re force parts
You should continue with your original thread instead of starting a new one for same problem. YOu need to post your model number for your motor so it can be cross referenced to other models.
roscoe
Re: re force parts
You really have to be very specific on these things.<br /><br />In case you didn't know, these motors were made up in many configurations, using many different parts that were stacked up in the warehouses.<br />As an example, Mercury Force made over 54 different models of the 90hp motor, between 1990 and 1999.<br /><br />
What year? The 1990 motors were very different from the 1992 motors.<br /><br />In general, the 1989-mid year 1991 used the prestolite CD ignition. But the 1991E model still used the CD ignition.<br /><br />The mid year 1991-1995 used the Thunderbolt CDI ignition.<br /><br />The 1996-1999 used the CDM ignition.<br /><br /><br />You are going to need the model number, year, and on newer years the serial number, for both motors.<br />If you want to look some numbers up, here is the place to look:<br /><br /> http://www.mercruiserparts.com/selectModels2.asp?type_id=FORC
rlovioi
Re: re force parts
WOW!..... Lots of info. Sorry about the protocall, will work on that. Thanks for the info
