Re: i/o haters
plztellme
Re: i/o haters
I'm a newbie, so correct me if I'm wrong. I purchased a 1990 16' Starcraft (I think they call it a bowrider) with an outboard. I removed all the seats except for the recliner on the port side and will install a pedelstal seat for the operator (me) and one in the bow. Will use strictly for fishing. And I discovered through this forum, that I can tilt the motor up in sallow water.:):)
JB
Re: i/o haters
Re: i/o haters
Congrats on the boat, plz. Is there a question in there??
Philster
Re: i/o haters
Re: i/o haters
Congratulations. I/O's tilt up, too.
You are newbie, so won't correct you on that one.
high'n'dry
Re: i/o haters
Re: i/o haters
I don't like nor would I own and I/O but they also tilt though in some cases not clear of the water.
Silvertip
Re: i/o haters
Re: i/o haters
Perhaps he was trying to say "V-drive" or simply inboard. The only way to tilt one of those to have a hinge in the middle of the boat.
produceguy
Re: i/o haters
Re: i/o haters
Congrats. I kinda like my i/o.
DuckHunterJon
Re: i/o haters
Re: i/o haters
I guess the correct statement is outboards can tilt up further with out excess stress on the U joint. Either way, they both have their merits. The only true solution is to have one of each (hmmmmmm, this could be epanded to jets, v drive, inboards, diesel... I gotta go find a second job!).
skargo
Banned
Re: i/o haters
Re: i/o haters
Gotta watch that "sallow" water.
Home Cookin'
Re: i/o haters
Re: i/o haters
Outboards tilt up higher than inboards, giving them a distinct advantage over I/O for shallow water use. Assuming you are looking for a little advice on that technique, first you want to be sure your motor is still deep enough to pull water up into the cooling system. The tell-tale helps, as well as sound.
When the motor is tilted up and running, you lose a lot of steering control especially in strong currents. You also want to only run slow so your motor's force isn't killing the tilt system.
When you run in shallow water you will be kicking up a lot of mud and sand. Be mindful that you don't want to suck alot of that up in the motor and be sure to run it hard in deep water to clear it. Don't use reverse (much) in shallow water for that reason--going forward you leave it behind!
Don't run tilted up over rock bottoms or hard obstructions. Your motor can handle mud and sand only.
Be mindful of weeds getting on the prop--they can block the water intake. clear them periodically. After I get out of shallow water, I often give a burst in reverse to clear it (after the prop has stopped spinning forward).
If you want to move around a lot in shallow water fishing, get an electric trolling motor.
