Re: Re-installing the LU Inline 6 Merc
Thanx Laddies and Clams!<br /><br />Went together nicely, I wound up using neutral. Tested forward and reverse, all good
<br /><br />Found the source of the water in oil contamination and sorted that out aswell
<br />Will refill from the drain plug as per your instructions later this week.<br /><br />The engine is now totally rebuilt.<br />Carbs fully rebuilt<br />Fuel pumps fully rebuilt (Including the casings ;P)<br />Water pump checked (Always had good tell tale)<br />Stator earth corrected and improved.<br />All ignition earths redone and verified<br />Trim and tilt. Fully rebuilt.<br />Steering. Stripped and cleaned. Great improvement.<br />Link and Sync done to clams' post<br />All grease nipples greased.<br />All suspect electric wires replaced.<br />All air intakes in the casing and shrouds opened.<br />Vacuum side of fuel line fully rebuilt.<br />Tank cleaned and checked.<br />Rev counter reading verified. (Is/was out by a lot
, and promptly blew up a day later :-/)<br />Compression test good +-120 PSI (+-1) on all cylinders<br />Reed valves seem ok since I can idle in neutral at 750rpm and shift into gear without the motor dieing. Getting around 600-650rpm in gear iirc.<br />Lotsa rain here the last coupla weeks so the dam is filling up nicely.<br />Wake board and tube ready for action.<br />Apholstry redone here and there.<br />We're considering a voltage regulator due to the speedo blow-up, but it could've been a spike due to the bad earth on the stator.
