Re-packing rudders (28' Bertram)
STeveZ
I kept tightening them down all last year and the leak(s) kept returning so I better repack them this year. Is the packing up in the cap portion of the assembly? Any instructions, photos, sketches would be appreciated.
tommays
Re: Re-packing rudders (28' Bertram)
<br /><br />you will want a packing puller to get the old stuff out<br /><br />
<br /><br />there are a lot of types but it should look something like this<br /><br /><br />tommays
STeveZ
Thanks guys, just what I needed!<br /><br />BTW, the guy at W. Marine said its a PITA job, true?
arks
Originally posted by STeveZ:<br /> BTW, the guy at W. Marine said its a PITA job, true?
It's not too bad if you can get to the stuffing box. I was able to wiggle into a semi-comfortable position, reaching over the tranny with the exhaust riser bumping into my head. <br />That "pick" Tommays showed is really necessary. I tried to do it by making my own but ended up wasting half a day and spent the 20 bucks (!) for it. <br />I recommend GFO packing (it's referred to as "low friction" packing in the link I posted). It's expensive but will last longer than the stuff WM sells. It also can be tightened so it leaks less then conventional flax.
