Re-secure Snaps?
JustABitAskew
Hey folks! I've had a couple of the snaps used to secure my boat's cover pull out of the fiberglass. What's the best way to repair these? Maybe... Fill the hole with epoxy and re-drill or...?
They make oversized screw snaps, that would be my fist choice
Lowlysubaruguy
Fill the hole with a high grade marine epoxy and then redrill it. And install a new snap.
First Clean the hole up first with a slightly larger drill bit then chamfer the top with a 3/8” bit ran in reverse just enough to give the epoxy a little extra area to Adhere to And to clean up som of that cracking around the hole.
JustABitAskew
Thanks. I think that's the right approach if the oversize screws don't work!
