mrmamiller
- Joined
- Mar 7, 2011
- 167
Motor is 1986 Johnson 110HP. I'm in the middle of trying to diagnose a problem which could mean leaky heads. Compression is an even 120# across all cylinders. Is there ever a reason to re-torque the head bolts other than within 10-20 hours after having new gasket installed? And, could I have a leak even if the compression is good?
The problem that I am potentially looking at is water leakage causing steam cleaning of my lower cylinders. I don't want to stir things up by needlessly re-torqueing the heads and possibly stripping threads, like I did once before.
The motor was fully apart ~100 hours ago. I have no idea if the heads were re-torqued or not. I know that there was a lot of on-water testing done at the time, so maybe they did. Now you know why I'm asking the question. Thanks.
