All the corrosion discussion on another thread has me somewhat intimidated. Instead of hijacking that thread, I thought I'd start another. <br /><br />I'll be dismantling my motor soon to replace water pump, rebuild carbs, do ignition work as necessary, etc. Even though it ran like a jackrabbit when parked, it hasn't been run in 10-12 years. It's never been left in the water and was only used in fresh water. During dis-assembly, should I expect corrosion problems with the bolts? Since it's trailered and only used in fresh water, are anti-seize compounds needed during re-assembly?<br /><br />BTW, I plan on laying it down with sparkplugs up, removing them and pouring oil in the cylinders and leaving for several days to loosen the rings. Is Marvel Mystery oil the best for this or some other product? Also, if one of the pistons is bottomed, will I fill the intake manifold with oil?<br /><br />Motor is 1977 Evinrude, 35hp, model 35703.
