reading max rpm
dave37
1985 50hp Mercury outboard two stroke, 4 cylinder,long shaft. Can I use my Fluke multi meter to read rpm from the tach plug at the front of the control box? <br /><br />I have an inductive pickup for the meter, but it would be easier from the plug on the control if possible. Also, my manual hasn't come in yet, any idea what the WOT rpm range for this engine is? Engine is currently outfitted with a 13 pitch 3 blade prop and I just want to make sure previous owner didn't make a prop selection that could cost me the engine over time.<br /><br />Thanks!
ronmold
Re: reading max rpm
If your meter has a frequency range yes but you'll have to divide the reading by the number of poles on the flywheel/stator. Better to just get a tach installed.
2cycle
Re: reading max rpm
According to the Clymer manual your WOT RPMs should be:<br /><br />4800-5500 (up to serial # 4576236)<br /><br />5000-5500 (above serial # 4576236)<br /><br />not sure which one you have, but hope this helps.
