Im pulling my hair out with this motor. A mercury 50 hp like a 80 model.
I have cleaned and cleaned the carbs over and over and it still seems like the motor is not getting enough fuel. I have tried adjusting the carbs on the water with no success.
Any idea guys what might be going wrong?
What is the best solution to soak the carbs in?
The motor will not run or peak out at fuel throttle and its bogging the entire time. I have cleaned the carbs probably 6-8 times.
The compression was checked and i was told it was like 120. Is this low compression? The guy at the marina said it was good pressure.....
