FreeBeeTony
- Joined
- May 15, 2002
- 3,997
See attached pics......
The mount kit came w/ (2) bushings, (2) fiber washers and (2) flat washers; I installed the bushings w/ the knurled edge facing down.
The screw kit came w/ (2) fiber washers and (2) spring washers......
Question is...........which washers do I use.......flat or spring?
I read somewhere that if you use the flat washers the front mounts need to be moved down ~025".
Any advice out there???
