Rear Engine Mounting Hardware
FreeBeeTony
See attached pics......
The mount kit came w/ (2) bushings, (2) fiber washers and (2) flat washers; I installed the bushings w/ the knurled edge facing down.
The screw kit came w/ (2) fiber washers and (2) spring washers......
Question is...........which washers do I use.......flat or spring?
I read somewhere that if you use the flat washers the front mounts need to be moved down ~025".
Any advice out there???
Ayuh,.... Not sure Tony, but I'll bump this back to the top,.....
Bt Doctur
the last one I did used the knurled mounts and no washer to have good alignment. adjusting the front mounts accorgingly.
I try to use the older style when I can get them though.
FreeBeeTony
Thanks BT..........
Just re-read the instructions............looks like you only use the flat washer if you can't drop the front enough.
