CD Maynard
Thread starter- Joined
- Jun 3, 2009
- 2
I have restored a 1964 Lone Star Reliant 18'. I mounted a 115 HP Mariner with a manual jack plate on the transom. The boat really needed a longer shaft engine. I re-drilled the jack plate to lower it the 2.5 inches needed to get the cavitation plate where it should be. The boat handles great but at higher speeds it has splash between the motor and the transom that comes up through the middle if the jack plate. Any ideas as to how to solve the problem. I was thinking that a splash shield of some sort could be bolted on the jack plate to cover the area. I just am not sure how much lift it might give the transom by doing that. The splash well does it's job and it is not taking on any water but I am concerned about the water around the engine itself. It also has a rooster tail from the transducer mounted on the rear of the transom. Originally the transducer was up front and through hull. Maybe that is why it was mounted that way????? Any suggestions would be appreciated.
