reassembling of outdrive
Frankiea87
hey i have an alpha one drive... when i bolt the lower unit back with the upper unit.... where the shift shaft connects to the lower unit shift shaft... does that matter with positioning for forward and reverse? .. i know when installing it on the boat itself it hasto be in forward..
Don S
Re: reassembling of outdrive
Yes it does. You must have both the upper shift shaft and the lower unit in forward. when the upper and lower are assembled.
After all the work of changing the impeller, the lower will probably be in neutral. If the prop shaft turns and the vertical shaft doesn't, you are in neutral. Then when you put the upper on the lower, just turn the upper shift shaft CCW a little till the tow fit together. Then turn the lever forward and turn the ujoints CW and the propshaft should turn and the shift shaft shoe should face forward.
Bt Doctur
With the lower unit in some type of stand, you turn the splined shaft fully clockwise while turning the prop counterclockwise till locked. lower the upper inplace making sure the "foot" part is facing in a straight line (inline with the prop shaft) ,engauge the splined shaft, continue lowering untill seated,
Frankiea87
when in forward.. which way should prob turn? if your looking at it from the back (as if it were on the boat and you looking at back of boat)
Bt Doctur
When the drive is in gear and the motor is running ,the prop turns clockwise.
When installing a drive you shift it into fwd, shift the control box in fwd, slide the drive on , maybe turning the prop slightly counterclockwise to line the shaft splines up,and the prop should LOCK trying to turn it counterclockwise and ratchet clockwise when fully installed..
Don S
You might want to go up to the Adults Only sticky at the top of this forum, and go to the Manual downloads and download manual #6. The discriptions and pictures will explain in detail how to put it together.
