I finally tore down my '86 Blackmax to repair a cylinder w/low compression. The cylinder wall doesn't seem too bad, we're hoping to just hone it. This cylinder/piston is oversize, .015. The bottom ring is welded to the piston on one side. See pics. I'm thinking it overheated because of a plugged jet in the carb causing to lean out??? I bought the motor this way, knowing about the bad cylinder.
Maybe someone can tell from the pics what may have caused the problem. I'm planning on installing new rings on the other pistons, and installing a new piston/rings for the bad cylinder. Any advice will be appreciated.
