Bigmykesboat
Thread starter- Joined
- May 10, 2012
- 16
ok ive got the bright idea to do it mysef! i want to replace my wear ring an rebuild my pump i saw a video an it looks easy enough several methods on wear ring removal from freexer trick to melting with soldering iron to cutting with wood chisal an pump rebuild looks alot like rebuilding wheel bearings knock the old ones out an press new ones in i have a friend with a press to put the bearings in with i was wonderingwhat to buy. so far on my list is new wear ring pump rebuild kit blue loc tight a neoprem ring to remount pump against a implor removal tool a preasure tester to make sure my cone dose not leak amimissing anything i dont mind buying the right tools for the job a leason i had to learn the hard way thank you for all your time an help an thank you i boats for this fourm
oh yea an a new shaft
