Rebuild of 70's era airboat with v6 corvair
s1120
Re: Rebuild of 70's era airboat with v6 corvair
I would think a tranny would mess up matching the prop pitch to the boat.
ShrimperJosh
I figured to match the prop using second gear on a 3 speed transmission, then on open area water I would be able to cruise at a lower rpm in higher gear, and in a sticky situation could use low gear and get the engine rpm into the power range. If it doesn't work out as well as that, I will get rid of the trans and add in a reduction unit. If you never try, you never know, right? Could be that I try reverse and almost flip the boat over backwards, but it could work out too. I figure to have the prop angled up slightly for planing, and theoretically it should provide just a little lift if I were to reverse out of some sticky mud. I guess all of this is a moot point though, as I still have to build the boat as of yet. At least I have a goal in mind, and good people on here to help me along the way. I think it'll be frustratingly fun!
archbuilder
I don't know jack about air boats....so I will sit quietly in the corner, have some popcorn :popcorn: and watch this thread! I'm really interested to see where you end up going with it, great project!
ShrimperJosh
So I read somewhere that people have used automatic transmissions with airboats, but nowhere have I read about a manual. I think I can rig it up to a shift linkage, it'll be interesting to say the least. Archbuilder, did you bring enough popcorn for the whole class? I think we're gonna need it!
ShrimperJosh
So, I've been looking at plywood and prices, and of course pliability of the plywood. What I am thinking is using 1/4 in. plywood in two layers and gluing them together, to make the bend of the bottom of the boat a little simpler. That way it would still have the half inch thickness for strength, but be more pliable during the build. Any thoughts?
archbuilder
I have never messed with it, but vacuum bagging a layup like that would give you a nice bond. Probably overkill, but it would sure give you a stout layup.
submariner1980
What doya think about variable pitch propeller instead transmission?
Pro: trust or speed regulation, brake, reverse, weight saving, easy to install, cool noise when pitch changes.
Con: PRICE
ShrimperJosh
Con: PRICE
Honestly, I would love to have variable pitch prop, but price is out of range for a while. And just to be different, think of how cool it could look if I bolt in a manual transmission. You just don't see people running a clutch on the water much, if at all. An auto is easier, but if I could use a manual and run a linkage to the shifter, it would look cool as all getout. The likelyhood is that it won't be worth the trouble, but will be interesting anyway. I may even try to build the prop myself, if I can figure out the pitch and get the right wood for it. That is a project in itself though! Would put woodworking skills to the test.
