JKTrevecca
Thread starter- Joined
- Sep 20, 2009
- 110
I picked up a 1982 70 hp today that the prior owner was running at WOT yesterday when he heard a "rattle" and now the engine is locked up. I haven't torn into it yet to see how bad it is. I paid $45 dollars for it and got the entire assembly with the detached/external trim pump and hoses, all of which work. The motor is clean and as far as I know, the lower unit is good, the electronics are all good, and it was running great until the catastrophic internal failure.
Assuming it broke a rod or has a hole in a piston, I'm am weighing the option of re-building it or selling the parts. Is there a market for used parts? If so, would e-bay be my best option in your opinion?
How much would the trim pump be worth used? Lower unit? etc...
Lastly, would I be able to use the trim assy on my non-power trim 1979 2cyl 40hp Merc? What all would I need to do to make that work if it's even possible. Could I somehow swap my 40hp motor onto the transom bracket this motor uses?
Thank You!
Thank You!
