rebuilding 53' john 3 HP,High speed needle valve stuck
rum riverguy
I'm rebuilding a 53' JW-10 3 HP, I'm just getting to the carb now that I've rebuilt the entire ignition system. My problem is the High speed needle valve won't turn at all. Even with the packing nut removed. First time I've been frustrated rebuilding my now deceased grandfathers little Johnson 3. does anyone sell rebuilt carbs, or needle valves??????? :confused:
DHPMARINE
Re: rebuilding 53' john 3 HP,High speed needle valve stuck
Try soaking the whole carb bowl in penetrating oil a few days,then try again.Use gentle heat (propane).<br />Be careful of the fumes.<br />DHP
rum riverguy
Originally posted by DHPMARINE:<br /> Try soaking the whole carb bowl in penetrating oil a few days,then try again.Use gentle heat (propane).<br />Be careful of the fumes.<br />DHP
DHPMARINE
Did it work?<br />DHP
