rebuilding '55 15hp carb, question on the needle seals
Philip_G
Hello,
I pulled my carb apart to rebuild it today and on the blow up diagram that came with it it showed two seals between the needle vale packing nut and the needle. The kit I got has round flat washers about 1mm thick and o-rings that were a little too big for that hole, is using two of the flat washers OK?
also I can't remember what the nozzle gasket looked like, was it that round cork gasket? I hope so because that's where that went :D
Daviet
Re: rebuilding '55 15hp carb, question on the needle seals
Sounds right.
