Nickypoo
Thread starter- Joined
- Mar 21, 2012
- 287
Hello everyone, this is my first post here.
My dad and I are basically completely rebuilding a 1984 Bayliner Capri, Model 1950, Volvo AQ125A (Volvo 2.1L w/ closed cooling system). It was our neighbor's boat and he bought it new in 1983 and used it for like 2 seasons, and it has basically been sitting ever since. It even still has the '84 boat registration and trailer plate stickers on it. The problem is he had it sitting in his driveway without any kind of tarp or cover on it, so everything is rotted out or corroded :facepalm:. He did give it to us for free so we have that going for us.
The rotted structure is another story and doesn't pertain to the category I'm posting in, so I'm not going into all that. We do have pretty much everything gutted from the fiberglass shell though.
The engine is in ok condition considering its age. The bearings look good, and besides a little (carbon?) buildup on top of the pistons, the cylinders look excellent. I guess this shouldn't be surprising since he only used it a couple of seasons.
The (aluminum) head is another story. While the bearings and camshaft are great, the valves are rusted and the rear exhaust port had kind of a fillet corrosion around the entire edge, so the edge was gone and it had been rounded out.
So we decided to have the local cylinder head shop completely redo the head. They are called "American Cylinder Head Exchange", and I believe they are a national supplier. We dropped it off a week ago with the impression that they would fix it and call us when it was done. They said it would be about a week. I called today only for them to tell me that they disassembled the head and needed us to drop off a deposit. They could have called us or disclosed that when we dropped it off, but whatever. I went in to drop off the deposit and he gave me a very rough estimate of $550, not including the 3 valves that needed to be replaced. I payed a deposit of half the estimate, so hopefully that will light a fire under them.
Thank you in advance
Sorry if this is a little long winded, I tend to explain more than I need to. I will try to keep it as concise as I can.
Here is a little intro to my situation:
My engine questions start here:
So my questions are:- Is $550 a reasonable figure for a complete reconditioning of one 4 cylinder head? (Including the exhaust port repair)
- What kind of head gasket can I use? Can I get away with an automotive gasket since it has a closed cooling system and will run coolant? This will be run in salt water but if it has a closed cooling system I don't see why it would matter. (I already bought the headgasket set so I'm hoping this is ok)
- What other miscellaneous issues should we watch out for?
