Rebuilding bunks
PolishPrince
I found a link to an old thread that probably answered some of my questions but it's no longer on the server.
Here goes....... I have a trailer for a 24' pontoon boat and two of the bunk boards have rotted out (only 3 years old) I've read several forums with all sorts of advice on which kind of lumber to use when replacing them. OH...............and they're just over 20 ft. too. (one piece)
  • Use regular 2x4 pine lumber and they'll be fine.
  • Use pressure treated lumber because untreated will rot
  • Don't use pressure treated because of a chemical reaction between the treatment chemicals and the aluminum.
  • Use regular lumber but slop on a couple coats of varnish
The ideal lumber would be cypress, but they do not come in 20 ft. lengths. I checked with a LARGE cypress distributor, and no they can not be specail ordered.
So weigh in folks. What do you do, or what would you do?
bitterboater
Re: Rebuilding bunks
2x10 doug fir and a couple coats of paint to seal it.
redone4x4
mine are 2x6"s but i dont have a pontoon either. I would just get the best straight pieces of untreated you can find and paint or seal them and carpet after that. I would think it would be worth it since it should last you 8-10 years i would think before you would have to think about it again.
boat1010
When I had a pontoon I used untreated wood and painted them with a good quality paint and then put carpet on them. That was 8 years ago and the guy that has the pontoon says they are still looking good.
Jeep Man
2x whatever size you want to use. Only about 1" of the pontoon on the inside and outside actually touch. Spaced properly, you could use 2x4. Personally, I used 2x6 white pine.Length is not a big factor. They can be joined at any of the support brackets. I recommend using 3 bolts on each board at the splice to eliminate any warping or cupping, AND, countersink the heads to prevent damage to the toon.
