rebuilding carbs
DHPMARINE
Re: rebuilding carbs
Welcome !<br /><br />You need 3 carb kits.<br /><br />Basic knowledge.<br /><br />FACTORY service manual.<br /><br />the others just don't cut it<br /><br />DHP
LubeDude
A Manual for you engine.<br /><br />Carb Kits, Buy them here, or at your dealer.<br /><br />Carb Cleaner, Spray cans are ok, but if they are really gummed up you should soak them in a bucket of carb cleaner. Remove plastic parts first.<br /><br />Compressed air to blow out the openings. Sometimes its hard to get them clean without a good air supply.<br /><br />A good half of a day with nothing better to do.
Dhadley
All solid advice. I would just add to make sure to use quality carb kits. A lean carb can produce an unhappy piston. And you know what happens when a piston gets all mad and puffed up.
