cecilfrankum
Thread starter- Joined
- Apr 19, 2010
- 6
Lower unit broke several teeth had to rebuild. I have run into a problem never seen before. I replaced the regular gears with the Sierra heavy duty gear set which include pinion gear to match. I also have the OMC tool for setting tolerance from drive shaft bearing housing assembly to pinion. The new lower drive shaft + new pinion measured .025 without any shims added. Per OEM the spacing should be .02. When I tighten the screws on the upper drive shaft bearing housing the lower unit gears bind. Any one ever run into this problem. I have rebuilt several lower units over the past 40 years and never ran into this.
