Rebuilding Fuel Pump 1983 70HP Evinrude
MTBoat
I got the kit, took apart the old parts and "assumed" I could use the pattern to put it all together. Wrong. I think the former owner put stuff in wrong,,,,may be why it was struggling.
Does anyone have a simple step by step, or a link to a real break down diagram showing all the gaskets etc, or free place to be instructed?
I was hoping not to spend too much, or have to buy a service manual right now, as I only need this clear so I don't put a piece in slightly wrong etc...
xjdriver
Re: Rebuilding Fuel Pump 1983 70HP Evinrude
What part# kit did you get? Mine came with instructions, mabey i could take pics
MTBoat
[h=1][FONT=arial, sans-serif]xjdriver[/FONT]: That'd be real helpful, probably even if it isn't exactly the same, but, here is what I ordered on iboats.com. [/h]
[h=1]Fuel Pump Kit for Johnson/Evinrude 393103, GLM 40820 - Sierra[/h]
xjdriver
IMG_20130709_214333.jpgIMG_20130709_214301.jpgIMG_20130709_214158.jpgIMG_20130709_214131.jpg
Hope this helps, its a 0777774 kit but its similar, you think you could have the wrong kit?
Edit- whoops, pics are in wrong order
MTBoat
Very cool, thanks, no this is basically the same as mine, but, I got not such nice illustrations.
Who did you order your part from?
MTBoat
Thanks for all the help.
The previous owner apparently left on round gasket out of the mix, which, the illustrations made clear to me. It may be been the culprit to the fuel issues...will see.
xjdriver
I got it from a local marine shop called southern marine, its an omc part so it was a little pricey, but I guess you pay for the nice instructions.
