Rebuilding hyd.pump on T@T
jerryjerry05
Now that Frank and RRitt have passed.
I don't feel comfortable messing with them.
​Does anyone know how to rebuild the T@T pump??
The mid sections I have need LOTS of work and I have replacement pumps that need rebuilding.
Once I get all the parts, brackets and trim cyl and lift cyl. I'm gonna R@R both mounting brackets and kingpins etc.
Since I have twins It's gonna be a big job.
I've rebuilt the electric motors.
So anyone do it as a hobby?
Or cheaply??
Thanks,Jerry
​I saw the post from PNW a Jiggz
Anyone have a complete parts breakdown on the hyd. motor?
I see the one with the valves but nothing on the other side.
TY
pnwboat
"I saw the post from PNW a Jiggz
I see the one with the valves but nothing on the other side."
I assume that when you say that "I see the one with the valves but nothing on the other side." you are referring to the side that is held in place with the bolts that contain the ball bearing check valves. Any damage to this side of the valve assy. would probably require re-machining or welding etc etc. Unless you have signs of corrosion or anything like that, I would advise not taking that part of the valve assy. apart. The most common failures are the rubber "O" rings which are all on the two directional and the one shuttle valve.
jerryjerry05
That's the answer I was looking for.
​Long time ago I took one apart and thought I'd made a mistake.(I did)
I didn't see anything in there that looked like it needed replacing or any O-rings in there.
If it's just the seals in the relief part?? I think I can handle that.
I already ordered the seal from B@S
​If that's all it is?? Then I've been afraid for nothing.
Thanks
