Re: Rebuilding Power Head
Brian,
You can get the timing very close or right on , by doing Joe reeves method.
Basically, you need to remove and ground the plugs, advance the throttle to wide open, turn over engine and set 4 degrees after recommended timing.
Thats it basically, but do a search , I may have missed a step.
You'll need to verify on the lake , either tied to trailer , or going down the lake at WOT.
But, I've never had a problem running motor through breakin , then checking at WOT.
You told me in an earlier reply that you verified it was going into reverse, didn't you ?
Yes max spark advance and everything else in the link and sync. is CRITICAL.
You wont get any higher compression at WOT, then you will doing it with all plugs out.
I've never even heard of checking it with motor running.
Yes when your rings seat your compression will go up .
You also know that the wiseco pistons must be warmed up before your comp. reading will be correct.
All comp. tests are more accurate on a warmed up motor , but with wiseco's its even more crucial, because there forged.
The carbs don't effect compression readings.
Again anything but a thorough and complete rebuild of carbs , is NO GOOD !
With the money you have in the rebuild, its rediculous, and VERY risky , to not rebuild them.
You don't have to have the guage, most kits come with a paper one thats ok.
Not really needed though .
Set floats level with the carb base or ever so slightly higher.
And be sure there level across the front of float to carb .
The choke solenoid , should have been checked during link and sync.
There are no short cuts to the procedure, it must be followed to the letter in the order given.
If you keep taking shortcuts, ie: carb rebuild , timing not set , max advance , etc.
Your going to be right back where you started , with a ruined motor.
Please do these things correctly and completely,
Its A MUST !!!
One more thing you said its only run 15 - 20 min.
What the heck breakin procedure are you following, because its not RIGHT.
Your idle breakin alone is more then 15-20 min.
Brian , check your pm's
KYHunter
