MASTER Brian
Thread starter- Joined
- Mar 26, 2006
- 738
Re: Rebuilding Power Head
Everything appears in good order, the factory height, just doesn't work. It places the shift lever to far back, to were it hits the block, when all cables are hooked up. I guess it's 20 years of wear and/or rebuilds.
It does shift just prior to the carb opening, just not much prior. It doesn't "bang" in or "jump" out, and I rarely get a grind, so it must be really close there. Either 1 more turn up on the rod or a slight adjustment to the cable. I'll play with the cable 1st.
Thanks for your response to this, it does clear up that my thoughts were wrong. I wanted to be sure.
It opens, just prior to the carbs moving, I'd like a tad bit earlier, but if I get it to not grind, I won't complain.
