SSTKO81
- Joined
- Jun 1, 2009
- 354
I feel like this post has kinda meandered so I’m going to update with as much info as possible.
The 140 was pretty much rebuilt over the winter. -reason was the number 2 rod bearing spun and it was knocking like a tractor with no oil pressure. Everything was removed cleaned and inspected; and replaced as needed with the exception of the camshaft, which stayed home. Crank, #2 rod and piston are out of a donor and have brand new bearings and rings. The engine was reassembled with all new bearings and clearances were checked w plastiguage before final torque. Engine turns over freely and while compression isn’t awesome, it’s between 110-120. Oil pressure is great at 40psi @ 1500 rpm.
This thing is a b!#¢* to get started. You have to pump the throttle (gas shoots out of the carb just as it should In a nice, tight stream; I will say one of the Venturi boosters is missing tho) it tries to start but unless I bury the throttle it just won’t fire.
Once it does fire you really have to feather the throttle to find a happy place where it’ll stay running. It seems to be best at 1500-2000rpm, runs smooth at that point, no misses or what sounds like detonation. If the throttle is backed off to say, 900-1100 rpm (if I can keep it running) it shakes violently and I can hear what sounds like detonation. -naturally I first went to the carb settings here and turned the mix screws in all the way and back out 2 turns. Upon adjustment the carb likes to run with both screws out about a 1/2 turn (would seem way too lean, but ok) idle speed screw is having to be turned way in to keeps the engine running. 900rpm is about as low as I can take it and it will begin to lug and sounds like detonation. But I can run it up to 3k and it’s smooth as butter.
So timing.... forget about it. Won’t do anything less that 12* try to move it to 6-8 where it should be and it’ll die before it gets close. So that’s where I’m at. Dizzy seems to be ok after replacing cap/rotor and wires. No miss fires, dwell is appropriate and plugs are new acdelcos. IDK....
