Halstead666
Thread starter- Joined
- Jul 23, 2014
- 19
Recently rebuild engine (rebored block, new pistons/rings, new heads) and at initial start up got a lot of kick back/backfire in carb but no start. Discovered my distributor/rotor was not in correct position....redid per the owners manual for a disturbed engine...TDC on #1, positioned rotor to #1 on cap moved 1/8th counterclockwise which put it on #2 .....etc.. When starting it feels better and seems to almost fire up completely but just doesn't get there. Engine rotates fine, compression was checked all 8 were pretty much 165 or better, old gas was drained/new marine gas was added to tank, getting good spark, tested batteries (6 yrs old) and each was getting 12 v but tested border line weak on the load test. Any suggestions?
