copelandcf
Thread starter- Joined
- Aug 26, 2008
- 28
I have a 2 barrel Merc carb for my 1989 Chris Craft Cavalier that I recently rebuilt. Now it wont start at all. I can see fuel going into the carb when I crank it but it wont fire. This was my first carb rebuild but I felt pretty confident in the end.
I rebuilt it originally because the boat would idle fine, but would cut out and stall at 2k rpms. When you looked inside the carb one of the bowls was bone dry and the other was wet, so I assumed something was clogged and rebuilt. I left the float alone and made no adjustments other than taking off and putting back on. All metal parts were soaked in berrymans for 20min+. There is a new needle and seat, but I reused the accelerator pump because they sent me the wrong style even though I asked for the "newer" bent style.
After rebuilding, I reset the dwell which seemed to be off a few degrees after rebuilding. The idle mixture and cam are set to initial settings. I did pull the plugs and interestingly enough plugs 3 and 4 were wet but 1 and 2 were dry. I dont know if this means anything or not. I would like to reset the timing but I cant get it running. Any ideas of what to do next? Am I supposed to put any fuel in the carb to fill up the float assembly? Thanks for the help. Cavan
