volvo aq130d(no timing belt),replaced plugs&wires, set timing(8btdc), adjusted valves, rebuilt pair single throat solex 44's. sync'd carbs, when you hit the throttle hard they back fire, when you push it easily thru no problem, i noticed the accelerator pumps have adjustment on external lever/shaft/spring. what to do? would timing adjustment help?
