recoil spring for old johnson
kvgr21
QD21 1960 johnson 10 hp motor. 3 inches of the spring snapped off, that holds it to the middle. heres my question......can i take the end that has no loop and make a little loop and weld it or will i have to buy a whole new one? and if i have to buy one, where could i get it? i looked around and didnt find anything for a 1960. thanks
F_R
Honorary Supreme Mariner
Re: recoil spring for old johnson
There is no reasonable reason to be dinking around trying to fix a busted spring as common as that one. Besides, it will probably break again if you do.
The part number is 307563 from any Evinrude dealer in the world. OR Sierra Marine 18-6501 right here at iboats---but it says they are out of stock. I hate it when that happens, but there are many other people selling Sierra.
jshouk
or if you want to try to use the old one anneal about 6 inches of the broken end with a propane torch until it's red hot and let it air cool. bend the annealed end around a 1/4 inch bolt or rod in a vise until you have a hook and give it a try. i retempered the end when i did mine but i think soft is ok. good luck. jon s
regulator23
I fixed one of these tonight. I held the band with vice grips about an inch from the end. I heated the end with a propane torch and bent it just like the old piece was bent. Cold water to cool it and it works fine.
samo_ott
They are cheap and easy to find. Only about $10. But I had one break on me in May and I had no spares so I MIG welded it and last I knew it's still holding. I know it was cheap but it saves a 45 minute one way trip to the OMC dealer. I have since ordered several and I now have a supply since last May when it happened.
kvgr21
just bought one, thanks
