recoil starter spring
fishr
Hi all,
bought a new recoil starter spring, installed it... and 2 times now the spring loop that goes on the outside of the housing has retracted into the spring housing on me and I have to put a new bend on the end that comes outside of the housing!.... What am I doing wrong here? this spring is a pain to rewind in the housing just to pull a few times and have to do it again!
1978 15 hp Johnson
Rick.
Re: recoil starter spring
That has happened to me many times with my 4 HP and 9.9 and 15. Here is what I do and it may not be correct but it has worked. I reform the loop around 1/4 or 3/8 copper tube. Then I cut a piece of tube the width of the spring and insert it in the loop and then take a small tie wrap and put it through the tube and crimp it around the spring. I've done it three time and it hasn't failed me. I wonder if the springs aren't too tight but in all honesty I didn't think I had them any tighter than they needed to be to pull all the rope back in. Best of luck. Rick.
fishr
Thanks! that worked, did the trick for me... thanks alot!
