Recommend a switch panel
polk county
http://www.iboats.com/Boat_Switch_Panels/dm/*******.098935902--**********.114616477--view_id.216629
Can anyone recommend a switch panel for a my aluminum 15ft tracker? For my purposes I think fuses would be fine. I need switches for navigation lights, courtesy lights and aerator. Also I don't understand how to mount and seal a switch panel. There is nowhere on my boat that is free of spray. Here is a picture of my boat. Where and how should I mount the switch panel? http://www.trackerboats.com/boat/?boat=3135
Thanks for the help
ken52
Re: Recommend a switch panel
Somtimes people choose panels because they match (visually) on their boat surrounding. What ever you choose make sure you have a few extra switches because down the road as you get more involved your gonna be adding "stuff" to the boat. Also consider where you are mounting the panel to determine size limitation for the panel. Hope this helps.
Mark_VTfisherman
.....Can anyone recommend a switch panel for a my aluminum 15ft tracker? For my purposes I think fuses would be fine. I need switches for navigation lights, courtesy lights and aerator. Also I don't understand how to mount and seal a switch panel. There is nowhere on my boat that is free of spray. Here is a picture of my boat. Where and how should I mount the switch panel?Thanks for the help
This one is waterproof, has room for expansion, and has LED indicator lights
As far as mounting, without knowing if you have a console or will be tiller steered, what you have for options, etc., it is hard to say where... it will mount in any flat bulkhead or console location. I assume you will be in freshwater not salt so splash shouldn't be an issue with this panel.
