Fireman431
- Joined
- Sep 17, 2007
- 4,292
Re: Recommisioning a boat after 5 years of sitting
It can't all be negative. After checking the transom & floor, focus on the outdrive. If the engine was indeed fogged/winterized, there shouldn't really be much corrosion internally, depending on how good of a job they did and how much fogging oil was used.
The impeller will need to be replaced prior to the initial firing. But after that, I would feed the carb from a can of gas (or spray lubricated starting fluid) just to see if it lights for a second or two. I really wouldn't run it any longer than that as it's only a test fire. Then you can get into rebuilding the carb & other tune-up items.
Look on the positive side. You might have just found the deal of the year. I bought a 21' Trophy that was sitting for 4 years. 122 hours on the engine and it turned out to be one of the best boats I've even owned.
