I have a 1985 70 hp Evinrude. I took it out today to check some other issues, and a mechanic suggested I check at the battery for any A/C current. He said if I was getting more than 1/2 a volt at the battery, i needed to replace my rectifier. My digital meter would flash 16 then 11 then 8 then 2 then repeat the cycle. On D/C it said it was getting consistent 12.1. I have had some battery charging issues. Is this normal?
The problem with my boat is it will run great at WOT for 5 min or so then drop RPM and pick itself back up. It will go back and forth until it boggs all the way down then dies out. If I let it sit for a while, it will repeat the process again. If I try and restart immediately, it will go severly bogged down. There ar eno problems running the motor at idle, only under way. There is watery oil running out the side of the exhaust plate. The plugs also look like they have water on them when pulled, so I am assuming there is a water leak in the exhaust.
I ran it with the spark arrestor plate off the other day, and I saw fuel spitting back through the carbs on cyl #1. I plan on replacing the reeds.
I have cleaned the carbs thoroughly, and checked the coils with a timing light while the rpm's were going back and forth with no noticeable difference.
My questions are 1. do i need to replace the rectifier? 2. could the rectifier cause my problems? 3. could the water/ exhaust system cause my problems?
