MassillonBuckeye
Thread starter- Joined
- Jul 26, 2010
- 400
Replaced a faulty rectifier on 1978 Merc 70HP a couple weeks ago. First couple runs on muffs in driveway, tach was working. Water test later in the week and no tach and running rough(think its fuel at this point). Removed rectifier and testing bad now. Actually with analog meter, its testing bad. On a digital multimeter it's showing some continuity between ground and post a and c, but looks like about 3m resistance on one of the range settings. No continuity on any other range setting. Honestly, I'm not too sure how to read or set this digital meter and I can't find instructions for it. Tenma 72-2050.
Either way, the tach isn't working and I'm fairly confident it's connected properly. It worked when I first connected new rectifier.
What could have caused the rectifier to go bad so soon? Could be overtightening one of the nuts and the post spinning slightly cause this? One of the posts have have spun a fraction of an inch then I stopped. It had worked after that in the driveway though.
