I'm in the process of replacing the rectifier on a 1998 Johnson 225. I just received the parts, rectifier and gasket, today. The service manual calls for using gasket sealer on the gasket. The gasket I received, OMC part, has a peel off sticky side on one side. the other side does not. I would assume, I should apply the peel off sticky side to the rectifier and use gasket sealer, OMC gasket sealer, to the other side. Confirmation of this assumption would be appreciated. This is my first 'major' repair and want to get it right the first time. Thanks
