Re: Rectifier Regulator - 89 175HP Johnson
If the engine has a water cooled regulator, and the gray wire is from regulator, the gray lead thru the regulator could be open, which means you have to change the regulator. You need about 8 volts with peak reading meter at the gray lead.
