1993 Johnson 115 (TJ115TLETS)My tach started acting funny. At idle it would work ok until engine warmed up then it would drop to 0 rpm. If I revved engine to 1000 rpm it would start working again and stay until I dropped to idle.I checked the charging voltage when this would happen and it was up around 15v instead of the 13.5 or so it should be. I did the Joe Reeves tach test and the tach worked fine when gray wire was hooked up to the yellow/gray wire on the terminal strip. Bad Rect/Reg!!! When I contacted iboats to get a new one they were out of stock. I looked at MarineEngine.com's site and found replacement for $66.00 instead of the $170.00 or so that I had expected. Has anyone had experience with their parts and does anyone know how reliable they are? Thanks in advance for any response.<br /><br />Bill
