I have to replace the rectifier on my 1977 70 HP mercury outboard. I got the new part, which is the OEM part. I was just curious if there was anything special that I needed to know about to replace it since I have never replaced one before. Do you just hook the wires back up the same way they were connected? It actually shouldn't matter which wire goes where as long as I get the positive wire leading to the battery on the correct post because the other two posts are AC right?
