On my 95 Mercury 125, I replaced the stator, and when you ohm it out, it puts out around 120 cranking, but as soon as you you put the two stator wires back on the power pack, it only shows 25 on the DVA meter. Could it be the regulator is not working properly? And is there a way to test it? Also, would it be the power pack or the alternator terminal block? Thinking maybe the regulator cause the stator to burn out? Any help would be greatly appreciated, thanks.
ssdavis70
ssdavis70
