Hi,
I have a 1989 Merc 80hp 3cyl. I took a volt meter to the two yelow wires coming off my rectifier, and they each measured about 5.5 to 6 volts. Is this ok? You see, my tach was acting really funny, so I took my volt meter to the rectifier and received no reading off either yellow wire. I loosened and retightend the connections on the rectifier, fired it up and I got mesurements of 5.5 to 6 volts on both, and my tach started working. Are the readings I'm getting from my rectifer too low? Thanks!
