rectifier
stic88
i have a 1975 85hp johnson, a wire is bad on the rectifier, iboats has them but none of the numbers match. one of them is a 4 to 5 amp and the other is a 6 to 10 amp. how do i know or find out which one to get. the service manual does not say. and the numbers on the rectifier do not cross with anything.
thank you for your replies.
numbers on the part is varo R135 7352 in print
and 510885 D2 G 4 stamped on it
Will Bark
Re: rectifier
If you post the model number of your motor someone will be able to cross reference it with the correct part so you can order it.:confused:
stic88
Re: rectifier
thanks guys that answered my question. owe you guys one
