Recurring - Vro Conversion Question
docdoc88
Will Sierra Fuel Pump # 18-7353 ( which has inlet fuel / inlet pulse / outlet fuel ) ( also rated for 20 -30hp 1990 to 2000 engine )
Work on a VRO conversion for a 1989 evinrude 60 hp engine?? ............ the pump it calls for is the Sierra 18-7352 ... but this pump does not have the correct inlets / outlets for proper application. Thanks
ezeke
Re: Recurring - Vro Conversion Question
I would recommend that you use BRP part # 0438557. You can use the existing pulse line without the pulse limiter or you can just leave the pulse limiter in place. You will need to fashion a bracket to support the pump.
The 0438557 was used as a stand alone pump on the 1999 E65WRLEES motors and others, so we can judge that it is powerful enough for your application.
