Red colored spark plugs
Pudz
I have a... i think its a 1980. Evinrude 50hp. recently it doesn't have any power for the first 15 mins of use. but as i go along it starts to sputter with more power, and eventually it starts to work properly. i took a look at the plugs and they are an odd color. they are a redish rust like color (the tip and elctrode). What could this be.
Mas
Re: Red colored spark plugs
Sounds like you're flooded???
What color 2-stroke oil are you using...red?
MAS
Benny1963
time for a carb cleaning and comp check and fresh plugs ,comp it first
could be just needing carbs cleaned good oil and gas fuel filter inline,
link and sink and timeing check you can do it get oem manual for your motor if ya plan to keep
Pudz
im using blue oil, but the marked gas im using is red.
ok what is a link and sink
Mas
link and sync meshes throttle movement with engine timing.
More likely, you have a poorly adjusted float or worn needle and seat causing flooding.
MAS
Pudz
ok do i need to rebuild my carb, or would cleanning it be sufficent. also what color should the plugs be.
Benny1963
yes what i meant was , run compression first so ya know if ya need decarb .then rebuild carbs, not just clean, and check tuneing of linkage and timeing
are they dry or wet the plugs may also run spark test ,plent of info if ya use the search function.
Pudz
what is decarb? and the plugs are dry
Mas
Decarb??? Use a product called Seafoam...which removes carbon buildup from inside the cylinders...pretty much yearly maintenance for 2-strokes. You can get it at any auto parts store.
MAS
Pudz
is seafoam a fuel additive? what should the compression be?
Mas
Seafoam can be used as an additive and/or directly into the carb. The latter will cause the motor to smoke like a SOB...but it's normal.
Compression should be even between cylinders and in the 100s...below 100 is getting questionable. Obviously, the higher the better, but varies between motor design.
MAS
Pudz
ok. also what would be the proper oil/fuel ratio? thanks for all the advice
Mas
50:1 fuel to oil ratio
MAS
Mkos1980
You didnt use any gas additives like octane booster did you? One bottle of that in a car will turn every plug red.
Mas
I think the "red" is a dye to show that a marine gasoline tax was paid.
MAS
Pudz
no additives, and ya its marine fuel.
JB
. . . it doesn't have any power for the first 15 mins of use. but as i go along it starts to sputter with more power, and eventually it starts to work properly. What could this be.
Nobody seems to have picked up this part. It runs bad until it gets warmed up, then it runs fine.
I think it is running on one cylinder when cold/cool. Carburetors don't change their performance when the engine warms up. . . but electronics with a cold failure might start to work when warmed up.
Check for a good (jumps 7/16") spark on both plugs when the engine is cold. My guess is that one isn't there.
Let us know what you find.
coolguy147
well it might be sparking one that cylinder if he reaches wide open. he could get a spark tester or run the motor and then turn it off. right then check all the spark plugs and they should be hot and all around the same temperature by feel
