TwoRivers
Thread starter- Joined
- Mar 10, 2010
- 354
Hello all.
My motor is a 1991 Evinrude 15 hp. It has the remote controls with the red plug.
Sometimes when you turn the key nothing will happen. I've isolated the problem to the motor side of the wiring harness at the red plug (male side).
I'm pretty sure it's the yellow/red wire loosing contact at the pin connector.
When I apply pressure to the harness just behind the plug: the motor will start. If the harness moves or bends: the motor won't start until I move it again.
I've used an Ohm meter from the pin to the solenoid and the reading will fluctuate indicating something is going on?
Any tips for repair without splicing in a new connector?
thanks
rob
thanks
rob
