Bosunsmate
Thread starter- Joined
- Apr 7, 2012
- 6,135
Hi
Ive bought a Mercury 1970 Redband 50hp (500) that was seized. I got the powerhead off after dealing to a few seized in bolts and after getting hold of the mercury flywheel puller ive pulled her crankcase apart. The top big end con rod bearings had come apart and seized the top cylinder. Ive order a piston and needle bearings and will hopefully get away with a light hone on the cylinder.
I went to change the impellor in the meantime but when i dropped the leg the gearshaft didnt come apart at the lower leg and it ended up pulling the shaft right up and out of the lower leg. Its now stuck in forward gear and putting the shaft back in is not doing anything.
Is there anyway to fix this instead of pulling the propshaft off? After dealing with the rest of the motor id say itd be pretty good at not letting me pull it apart
Serial # 2947660
Thanks
Serial # 2947660
Thanks
