Mike Robinson
Thread starter- Joined
- Jun 29, 2005
- 752
Hello All<br /><br />I have an 5.6 meter (18 1/2 ft.) welded aluminum cabin boat with a 1994 150 hp Johnson outboard (commercial model). When I bought the boat, WOT was 4800 rpm with a 15 by 17 three bladed aluminum prop. I have since switched to a 15 by 15 three bladed aluminum prop and removed the hydrofoil from the leg. I now get 5300 rpm with a light load with the motor and trim tabs trimmed up and a speed of 33 knots. <br /><br />The cavitation plate is just shy of about 2.5 cm. (1 inch) below the keel and the motor is mounted in the bottom holes of the outboard bracket.<br /><br />We use the boat for ocean fishing and troll with a kicker (9.9 Yamaha). We run about 30 miles to the fishing grounds through sea conditions from smooth to 2 meter swells.<br /><br />My question is; Should I consider raising the motor or use a smaller pitch? Fuel prices being what they are I want to be efficient as possible.<br /><br />PS. I am also considering buying a Stainless Prop and keeping the Aluminum as a spare. Any comments on this would also be welcomed.<br /><br />You feed back is much appeciated.
