Reducing trolling speed
fishingdan
Hi,
I have a 19' bowrider with a 4.3lx mercruiser Alpha 1 outdrive. The current prop works great for water sports and cruising. It is a 4 blade aluminum Solas 14x21 prop.
I would also like to do some fishing trolling with the boat and I was thinking of picking up a prop that would be used when I'm on one of these outings. The current setup idles at about 3 to 3.1 mph per gps. I would like to get this down to 2 mph or slightly under that. What would be a good starting place to step down the prop for this use? I know I would have to watch rpms when running which would never be close to WOT in this usage.
Thanks,
Dan
Hard Head
Re: Reducing trolling speed
You can always use a trolling plate or throw out a drift sock.
fishingdan
Thanks. Those are options I considered. Not thrilled with either, but it may the way to go.
Wvawitrado
honestly to go through all that every time you would like to go fishing would seem inefficient just grab about ten foot of rope your drill and a five gallon bucket to make the best trolling speed you can get lol Its just real easy and works for me just a cheap alternative and time saver
fishingdan
You know what? I think I'm seeing the light. I'll try the buckets or some trolling bags.
Thanks!
K.P.
I wouldn't waste your time trying to pitch that rig low enough to troll. Your better off doing what the others suggested or investing in a separate out board motor like a 9.9 or 15 HP.
Another suggestion is do not rely on GPS for determining trolling speed. They are not as accurate for that purpose as you would think. I use a transome mounted paddle wheel option that connects to my sonar. After you calibrate them, paddle wheels provide very accurate WATER speed between 1 and 5 MPH. They are not very accurate at high speeds unless calibrated for that but they then loose low speed accuracy.
I mostly troll a river system here in Illinois. Trolling on moving water results in water speeds that can be vastly different from the land speed readings of a GPS. The same applies on wind blown lakes.
fishingdan
Thanks KP. I mentioned the gps speed because I did some testing on a static body of water. I normally fish in in-shore areas and there is always current to factor in.
